Main > Software Forum
Windows ScreenSaver Goes On While Using A Game Controller
<< < (6/8) > >>
loadman:
--- Quote from: efjayel on December 04, 2007, 02:01:48 am ---I'll still go for that batch file if you want to do it loadman. As for running Mala, I find it has some weird effects that I'm trying to fix so I'd rather not use that.
Attached Windows and command Exe (Use saver.exe in a batch file)
WindowsSSTogGui.exe was just for fun  :-)  (see attached pic)   :o
anyway your batch file may look something like this, I'm sure others have better ideas as I'm not bat file expert
ie
example.bat
--- Code: ---saver.exe off
mame.exe
saver.exe on
--- End code ---
You can then create a Windows shortcut to your batch file.. or whatever
When you work out your MaLa issue(s) please share (in the spirit of the hobby  ;D   )
zelony:
Modern monitors can still get burn in.  Even LCD monitors can.  If you don't believe me, stop by Click's Gaming Center in West Des Moines, IA.  I will show you a nice modern 17" LCD with screen burn in.
I only use the power settings now, it turns off the monitor when there is no activity.  It will make the monitor last much longer and is more sensitive to use of the system than the screen saver, so it may work better with the game pad.
Jeff
DaveMMR:
--- Quote from: zelony on December 04, 2007, 06:17:58 pm ---If you don't believe me, stop by Click's Gaming Center in West Des Moines, IA.
Okay, I'll go cash in my miles and meet you there.  ;D
Is it possible to get burn-in.  Sure.  But it's not a real big problem anymore with monitors since the 90s.  Everyone's "seen" a burned-in display, but no one can tell me for certain if these monitors were operated under normal conditions.  For the home user, a bigger concern would be the life of the monitor itself and energy concerns (i.e. the bill).  Which is why I agree with your second paragraph zelony, and is exactly what I do.
fjl:
Thanks loadman it works. Well sort of. The screensaver doesn't come on but the monitor still shuts off for that power saver setting. Can't win them all I guess.  :dunno
loadman:
--- Quote from: efjayel on December 06, 2007, 03:22:50 am ---Thanks loadman it works. Well sort of. The screensaver doesn't come on but the monitor still shuts off for that power saver setting. Can't win them all I guess.  :dunno
Well you could set the monitor shut off for a longer time than you would possibly be playing a game with a gamepad.  :-)
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
