Main > Software Forum
I need help to finish off my cabinet.... software wise....VERTICAL CAB
<< < (3/3)
loadman:
--- Quote from: nullb0y on October 15, 2007, 09:30:05 pm ---however my mouse still acts like its horizontal....
i guess i will rotate the mouse physically because this front end rocks ^_^
Nah, Just change options-controller-mouse   'Exchange axis'   ;)
--- Quote from: nullb0y on October 15, 2007, 09:58:33 pm ---okay i lied
now my games are all loading by default to horizontal and i have to manually change each one... is there a mame configuration file i should delite?
im using a normal mame.exe
An Easier way is to edit the section in mame.ini to:
### Mame CORE video options ###
norotate                0
ror                     1
rol                     0
autoror                 0
autorol                 0
flipx                   0
flipy                   0
or easier change options-mame config-options 'Rotate mame with mala'
nullb0y:
mala is pretty easy to use... ^_^
thanks for the help ^_^
loadman:
--- Quote from: nullb0y on October 15, 2007, 11:57:39 pm ---mala is pretty easy to use... ^_^
Cool.
If you discover things feel free to add to the wiki using your forum username and password
Aurich:
I have a vertical cab. I use iRotate with an ArcadeVGA and it works great. Mala too.
loadman:
--- Quote from: Aurich on October 17, 2007, 04:26:29 pm ---I have a vertical cab. I use iRotate with an ArcadeVGA and it works great. Mala too.
That is good to hear, maybe I shoud try that? .  When I set mine up I found that 95% things worked OK. Not quite good enough for me.
Navigation
[0] Message Index
[*] Previous page
Go to full version
