Main > Software Forum
Need Help with Zinc Configuration
<< < (7/7)
RecklessAbandon:
all i was saying is most of the files on your site work fine, its just a few that appear corrupt.
just seems strange to me. if it was my connection they all would be, if it was the server i'd assume same result, all being bad.
its just the fact its only a few and not all made me think its the files
http://members.lycos.co.uk/guru404/zincconfig1.5.zip <- that is a link to a bad zip and re-hosted i got, if its any help
Howard_Casto:
Well, as I suspected, it's on your end.  :)   I downloaded the file you linked to and it opened fine.  I still want to help though... I need some basic specs like your os, versions of winzip, ect....
JKnife:
I'm using WinXP pro and Winrar 3.42
I upgraded to Winrar 3.70 and got the same result:
"The archive is either unknown format or damaged"
I download and extract zipped files all the time and have never encountered this problem, so not sure how it's on my end.
Howard_Casto:
There actually seems to be a bug in winrar itself.
I use 3.60 (and have for some time) and it reads the file and extracts it fine.  The new 3.7 seems to choke on it though.  It should be noted however, that every other zip program I have on my machine opens it fine, including xp's built in zip support.  Using the "repair" function in winrar also fixes it.  I can re-zip the files and re-upload them, but in the mean time just use a better zipping program (like the one that comes with windows).
Thanks for you patience.
-edit-
Re-zipped files are up.  I confirmed that my recovered files had the error as well, so this should fix it.
RecklessAbandon:
top banana  :)
Navigation
[0] Message Index
[*] Previous page
Go to full version
