Author Topic: Galaxian (or Pac Man): How is the lower bezel mounted ?  (Read 1013 times)
Level42
« on: May 28, 2007, 06:14:13 pm »
I am curious about how exactly the lower bezel (the really dark plexi, with the CRT shaped plastic under it) is mounted. It was with my Galaxian when I got it, but I never figured how it was positioned.
The CRT shaped plastic simply seems to small to fit over the 19" tube.... ?
Any pictures would be awesome....thanks !
modessitt
  • Last login:October 17, 2021, 07:02:28 pm
  • Technician
Re: Galaxian (or Pac Man): How is the lower bezel mounted ?
« Reply #1 on: May 28, 2007, 08:09:57 pm »
There are two long brackets that attach to the monitor tube bolts on each side horizontally, that stick up alongside the tube.  These brackets have holes that the black monitor bezel screws into.  There are 4 plastic "clamps" that the screws pass though that hold the tinted plexi in place.
This is used on many 80's games, not just the Pacs and Galaxians/Galagas.   I know Spy Hunter used it as well....
As for pics.... I don't have any at the moment, but have some of these brackets at work and can get a pic of them if no one else has any....
Working Games:Joust CT,Gyruss UR,Pong,Battlezone UR#1
Current Proj's:Battlezone UR#2
Cheap/Free Cabs Wanted: DK,KarateChamp,Shinobi,Ghosts&Goblins,CircusCharlie,10ydFight,PolePositnCP,RallyX,Frogger
Level42
« Reply #2 on: May 29, 2007, 03:07:40 am »
Aha, that explains a lot ! Those are definitly missing from my cab  :'(
Pics would be greatly appreceated. Would mikesarcade.com or arcadeshop.com sell these ? I'll check it out...
