Main > Software Forum
Model 2 emulator and fullscreen? Can Mala(or other frontends) help?
SGT:
--- Quote from: unclet on July 17, 2007, 01:06:42 pm ---Also, is there a complete list of all available Model2(a/b) game names out there somewhere?
MAWS
Deluxe Search
Driver = Model2.c
unclet:
I got Daytona working and figured out I need to set the "Link Id =Single" and I can play it. Pretty cool.
However, for some reason, when I exit the emulator and go back into it, then the LinkId setting is lost. Is there any way to save this setting in the emulator yet so I do not have to keep setting it when I restart the emulator?
SGT:
--- Quote from: unclet on July 18, 2007, 07:20:37 am ---I got Daytona working and figured out I need to set the "Link Id =Single" and I can play it. Pretty cool.
I only had to set it to standalone once. Any chance your nvdata folder or daytona.dat is set to read-only? Have you tried setting it and exiting from the emulator via its gui intead of a forced exit from a wrapper?
unclet:
Not using a wrapper. Doing all of this manually for fun right now. I tried a few times to start the emulator (not full screen mode) and then selected Daytona and it wants me to resetthe LinkId again. I then decided to set the "Auto Fullscreen" setting via the menu bar and play the game in fullscreen .... pretty cool. Anyway, right before leaving for work this morning, I fired up Daytona (to show the kids) and it went right into fullscreen mode and did not ask me for the LinkId stuff.
I need to test again when I get home, but perhaps having the "Auto Fullscreen" set now permanently matters for some reason? Anyway, I am not at home to test this.
8way:
To solve the problem of Daytona not saving the LinkId setting or for that matter any game saving its setting the solution is simple. After you load the game and make your setting, simply click on “Unload Rom” from the emulator menu. The reason for this is if you just exit the game the “nvdata” will not be written or saved.
Navigation
[0] Message Index
[*] Previous page
Go to full version
