Author Topic: Which optical interface? Straight USB/PS2 or through an Opti-Pac/Mini-Pac  (Read 1238 times)
Joystick Jerk
  • Last login:October 22, 2023, 08:18:08 pm
  • Slave to the stick.
Now that a lot of optical products such as trackballs and spinners can include their own internal encoders and PS2/USB connections, I'm wondering what would be the best way to go for my new CP. Should I go for the self-encoded products with a USB hookup, or should I hook things up through an Opti or Mini-Pac? Does one have advantages/disadvantages over the the other? Any features missing in one solution over the other?
Specifically I'm looking at the SlikStik Tornado Spinner and the Happ Trackballs. If anyone has experience with both products and both of each products interface types, your opinion would be killer.
shorthair
If you're going new, I'd check out groovy game gear, for both.
(Definitely need wiki entries for gear and vendors. I may...)
Kremmit
  • - AHOTW -
  • Who the heck is that?
The Tornado comes with it's own USB interface already.
For the Happ TB, I'd a) buy through Ponyboy or Divemaster, NOT direct from Happ) and b) check the price on the Happ interface vs. Ultimarc or GroovyGameGear.
Joystick Jerk
About the Tornado, you can buy it direct from Slikstik and you can get it configured minus the USB/PS2 jacks so it can be connected through the Opti or Mini.
Still, any more opinions out there? I'm almost set to start buying my new CP components, but I'm still unsure which way to go for the optical devices connections.
« Last Edit: May 07, 2007, 09:56:06 am by Joystick Jerk »
Havok
  • Trade Count: (+17)
Get this instead of the Tornado:
Better Spinner
It's a higher resolution spinner. As far as connecting to the computer, I would go with the built in interface...
Joystick Jerk
I was mainly going with the Tornado, as I really liked the aluminum tops. After you mentioned the TT2, I stumbled across the extra token tops available from GGG, so I just may now go with the TT2.
Still, GGG should change the default spinner tops the TT2 comes with. Hands down the ugliest spinner tops out there.
RandyT
  • Last login:Yesterday at 11:46:17 am
    • GroovyGameGear.com
These are provided as very functional, "lower cost options".  The alternative would be to do what other vendors do and not provide one at all, forcing you to buy a "premium" one in order to even use the unit.
I thought offering these was a better option for those who might not have their own spinner knob already and for whom cost was an issue.  As for the "ugly" part. these look far better than 99% of the "off the shelf" knobs out there.  :)
RandyT
Chris G
  • Last login:April 16, 2023, 04:39:59 pm
I have been told (and I'm not sure if it's true or not, but it seems logical) that having a separate interface for each control set is a slight advantage over using, say a mini-pac, which has one for everything.
Joystick Jerk
I've been doing some reading in the meantime and noticed a few people mentioning this as well. I'm definitely leaning more towards the the USB/PS2 self-encoded options.
Havok
The Slikstik tops fit the TT2 - get the better spinner, and get the top you want...
Joystick Jerk
Really...
I wasn't sure about that, because the photos make the top look likes it's flush fit or integrated with the TT2. So I guess there's a small spindle on the TT2 that most tops could fit on?
Havok
It's a standard 1/4" shaft. Bling away!
miles2912
Or to answer your original question the mini-pac + normal (non-usb) trackball and the usb slik stick are a great combo.  The mini-pac saves quite a bit if you just need the one track ball interface.
Personally I love my slik stik tornado spinner.  You can search for experiences with Slik Stik to get a better feel for the company's ethics.
Don
Joystick Jerk
Oh, I've heard all about their... "dealings" before.
It's just hard to be picky in such a niche market.
