Main > Software Forum
Removing the mouse pointer on start up
gonzo90017:
--- Quote from: RyoriNoTetsujin on April 27, 2007, 09:26:46 am ---Personally, I edited that cursor to be a tiny 8-pixel circle instead of just a point.
Do you mind sharing it?
sega_mad:
Hi again, thanks for all the great info, I'm using MaLa for my front end. I downloaded Instant Sheller, and used the "black dot" cursor file, and pasted that into control panel, mouse, pointers. It did the trick.
On boot up, the cursor is completely hidden, but on shut down, it's still there (a white arrow)....any thoughts?
Thanks in advance
RyoriNoTetsujin:
Are you running XP?
Also, are you actually using Instant Sheller, or did you get it just for the cursor? I know that sounds like a strange question, but I want to rule that out before going too much further. It's significantly easier just to use I.S., boot into mala, quit (but not shutdown) and then use Tweak to import all the mouse settings (i.e. cursors, etc.) rather than poking around your OS trying to replace individual cursors/icons/etc.. There's no way that I know of (short of registry hacks that I'm not brave enough to do I suppose...) to edit the logon desktop options other than that particular version of TweakUI... and the logon desktop certainly extends to the shutdown event you're describing.
--- Quote from: gonzo90017 on April 27, 2007, 12:00:28 pm ---
Ummm... sure! Glad to help. ;D I'm at work right now, but I'll find a way to post it this afternoon.
sega_mad:
Hi again, thanks so much for all your help!! You guys are a wealth of knowledge.
I'm running (tiny) XP pro, revision 2...which is fantastic.
I have it all up and running now. Mouse is only a 1 pixel black dot, which is almost impossible to see, but if I need to change anything in MaLa, it's still possible! I did the whole lot through registry hacks. I just followed (to the letter) the "hiding windows" that was posted on this forum. While it looked/sounded difficult, it was pretty easy......only because the directions were so good.
Thanks again to all
gonzo90017:
There's an alternative to Instant Sheller made by some guys at Marcianitos.org It's actually pretty amazing. It's simply called Loader http://www.marcianitos.org/tutoriales/loader.php Only problem is that it's in spanish. Just copy the link and make a search with it on google when it comes up, hit the translate button. Here's a brief description of some of its features.
Replaces the windows boot screen
Gets rid of the windows welcome screen, shutting down screen etc. (autologon)
Disables Windows Sounds
Replaces the cursor with a tiny black dot (with me it still appears for a brief moment)
Gets rid of the windows wallpaper
The best part of all is that you have the option to use a sort of front end. Before your frontend loads a little icon appears and if you press a certain button it loads its frontend where you can launch any program you previously configured. In other words Internet explorer, or you can launch different frontends. You can specify the amount of seconds the icon appears or you can just make it so the menu loads every time you start your pc.
But if you don't press the specified button it just loads whatever program you configured it to.
Navigation
[0] Message Index
[*] Previous page
Go to full version
