Main > Main Forum
GP-Wiz Eco problem
<< < (2/2)
King Friday XIII:
I've been thinking about this and there is one detail I left out. I start the buttons and 2nd joystick at like number 15 on the GP-Wiz. Numbers 1-14 are not used.
Do I need to start at #1 and work my way up?
bfauska:
The order is not relevant.  I use the joystick inputs and then buttons 15-22.
Which joystick option did you check? There are two, one is under "interface options" and is not the one for using joysticks during the games, the important one is under "default game options" and the "controllers" tab.
I hope that solves it, because if that doesn't do it, I'm of no more use to you.
Good luck.
Tiger-Heli:
--- Quote from: King Friday XIII on April 03, 2007, 05:24:38 pm ---I've been thinking about this and there is one detail I left out. I start the buttons and 2nd joystick at like number 15 on the GP-Wiz. Numbers 1-14 are not used.
Not for MAME32.  There are some games that only recognize 15 or 16 buttons per joystick, so that might cause you problems with them, but MAME should be fine.
King Friday XIII:
I don't know what I did right but it works now. I rewired so that the button numbers start at 1 and go up. I did this before I saw bfauska's post. For some reason, it works now. I know now that it was not the numbering order because I think I skipped #2 in my rewiring.
Regardless, it works now but I still don't know why it did not work before. The settings in MAME32 are exactly the same. Maybe, I had a short somewhere? Who knows.
Thanks for all the help.
bfauska:
Too bad we didn't really solve anything, it's alway nice to know why something didn't work.
But really, who care's it works now.  Go have fun.
Navigation
[0] Message Index
[*] Previous page
Go to full version
