Main > Software Forum
Remapping keys for many games at once
<< < (2/2)
primetime34:
I use Mamewah...any help for that??
Howard_Casto:
Well I know how to do it, but it'd be a real pain in the butt.
What you do is make two ctrlr files, one for 2 player games and one for 4 player.  Then you write a batch file that makes ini files for all the 4 player games and sets the "ctrlr" variable to yoru 4player ctrlr file and use the 2 plaeyr ctrlr file in your main mame.ini.
primetime34:
--- Quote from: Howard_Casto on March 27, 2007, 03:28:11 pm ---Well I know how to do it, but it'd be a real pain in the butt.
Any chance we could get you to write up that batch file??
bfauska:
Could you do 2 installs of Mame in different directories and set one to sort for only 1 and 2 player games and the other for only 3 and 4 playergames and then use the lists as two different categories in your FE?  With this setup you would just tell each install of Mame to set the controls up the way you want for the games it is used for.
I haven't really thought this out but it seems like it would work. It would be like running some games off of an old release for better speed (which sounds like a common thing.)
I don't know, maybe there are some drawbacks I'm not seeing.
Good Luck,
Brian
primetime34:
--- Quote from: bfauska on March 27, 2007, 03:50:42 pm ---Could you do 2 installs of Mame in different directories and set one to sort for only 1 and 2 player games and the other for only 3 and 4 playergames and then use the lists as two different categories in your FE?  With this setup you would just tell each install of Mame to set the controls up the way you want for the games it is used for.
Good Luck,
Brian
That's a really good idea.....any thoughts by anybody why it wouldn't work??
Navigation
[0] Message Index
[*] Previous page
Go to full version
