Main > Software Forum
New AtomicFE user having a few issues..
youki:
Wouuah... i'm impressed Havok... it seems you master Atomic better than me!!!
Effectivly it could be the cause.
So as i said Havok , try to install the codec.
and if it didn't work , disable the intro video from AtomicManager.
shorthair:
The cfg didn't even have 'windowmode=yes' in it...but that didn't seem to work. It was the codec that did the trick. Had no idea. And I was missin out on the whole intro video. Thank you, Havok.
Dariusz:
youki.. I have atomic running now. The actual problem was when I installed a new harddrive drive under vista where I now use atomic, the user premissions assigned to the drive were only for read and noit write. What had happen was when using attomic manager, the configured settings were never saved, hence for the earlier earror I was experiancing. Now all is OK. Thanks for your assiatance.
BTW how do I add gemes from one games list to the faverots games list, and how can I switch to the faverots games list?
Dariusz
shorthair:
I thought maybe it would use your mame folders.....try this:
http://www.atomicfe.com/Downloads/ReadMe.pdf
youki:
--- Quote ---BTW how do I add gemes from one games list to the faverots games list, and how can I switch to the faverots games list?
Open you .cfg with AtomicManager, go on the "options" tab , on the "option 1" subtab.
Check the check box "Enable Favorite's list" , save and exit.
then if you didn't do specific key setting by default :
PLAYER1 BUTTON 1 add the select game to the favorite list
PLAYER1 BUTTON 2 Remove game from the favorite list
PLAYER1 BUTTON 3 switch to normal list to favorite and inversly.
If you want manage multiple favorite list, there is a plug'ins that allows that, but you will have for now to have precreate your favorites list.
Navigation
[0] Message Index
[*] Previous page
Go to full version
