Main > Main Forum
Another NOOB question
shardian:
He is already using mame32 by the way he is using a file menu. No need to go thru MALA to change things
moriartyds:
I'd do what rebelscum suggested.
Go into the game, press tab and go into inputs. Where it says analog x, press enter (it should turn yellow or something) and then spin the trackball to the left or right quickly. It will register as Mouse 2, Mouse 3, etc.. so you'll know which mouse is assigned to your trackball. Do the same with the analog Y, exit and return to game. It should work fine.
urbecrisch:
Seems to work. Now how do I adjust the trackball speed? Is there any way?
NickG:
roll it slower...just joking; in-game press tab and then select analog controls- you can adjust speed there.
urbecrisch:
Thanks. What are the suggested settings for Golden Tee?
Navigation
[0] Message Index
[*] Previous page
Go to full version
