Main > Main Forum
Where can I buy this Button? -calling all part gurus!!!!
leapinlew:
--- Quote from: Kevin Mullins on February 11, 2007, 01:14:57 am ---
--- Quote from: leapinlew on February 10, 2007, 11:55:39 pm ---BTW, how do these buttons work for you performance wise? For example, could they work as the fire button in Galaga?
Too small....they would fall right through the original mounting hole.
The whole thing is less than 3/4 of an inch in diameter.
Unless you are building a custom mini-mini machine or something.
naturally! I would drill a smaller hole for a smaller button. :)
ponyboy:
How about this one???
Ponyboy
Fozzy The Bear:
--- Quote from: Timoe on February 10, 2007, 11:40:08 pm ---I am building a wheel that needs four buttons. These two buttons came off a Steering Wheel Horn Button kit from a company called Sparco. The kit is $50. I just need two more buttons and I dont want to spend another $50 for the two little buttons.
Any idea where else I can get them?
They appear to be "push-in" style buttons.
Even if the other buttons are not exact, if they will work then I can just buy four of em.
I think those are Radio Shack push to make buttons....
Best Regards,
Julian (Fozzy The Bear)
Goz:
My local Radio Shack sells something very similar.
Russ:
Best Regards,
[/quote]
You mean Radio Shack push-and-it-breaks buttons? >:D
Navigation
[0] Message Index
[*] Previous page
Go to full version
