Main > Software Forum
GameEx LCD/LED Plugin 1.2 BETA Released! Need testers for LEDWiz features
headkaze:
I'm seriously thinking about converting my CP to use RGB LED's with two LEDWiz just so I can see my CP flash pretty lights in attract mode. The only problem is I'm useless at wiring things up (I bought my custom CP from ozstick). And I'm not sure if I will need to make a whole new CP or if I can just unscrew my old buttons and replace them.
squirrellydw:
You should just be able to replace them. The hardest part is wiring up the RGBs to the LEDWiz and that is only hard because of the small gauge wire. It is actually pretty easy.
What is BetaBrite??
headkaze:
BetaBrite is actually a scrolling LED sign. The plugin outputs the game name, joystick type, and button actions to the sign.
It would be awesome if they made them with full RGB support and higher resolution then you could use them as a dynamic marquee.
edge:
Nice job, headkaze. An all-in-one "bling bling" plugin.
I am still on the fence for the betabrite. I wish it has better resolution.
headkaze:
Latest features added
- Realtime color feedback while you configure your LED's (actually this has been working for a while, but I never mentioned it)
- Color mapping so you can map custom colors for color.ini
- Now LEDs lights up and flash leaving last LED lit with speak button actions feature
- Skip speak button actions feature with button (will not be available until next release of GameEx)
Oh yeah huge thanks to Tom for modifying the Plugin system to allow for the "skip speak button actions" feature! It will be available in the next release of GameEx which will be soon!
Navigation
[0] Message Index
[*] Previous page
Go to full version
