Front End Support > MaLa Frontend
Redoing the mame cabinet with Mala - Need some advice....
FrizzleFried:
You will have to go back to around .106 to avoid the disclaimer...or you can compile your own. Mr. Do has a good compiling instruction page over at mameworld.com.
shock_:
Recommend compiling your own... there's one line you can add to mame.c (well, two lines but one is a comment), to remove the disclaimers for things like "this doesn't work" which aren't removable via mame.ini. This post from headkaze is what you want to do. Mr Do's instructions are really good for the compiling side of things.
vettetekk:
Thanks for the replie. I started to follow the compiling instructions as outlined, and when I came to the line I was supposed to add, it was already there in the mame.c file!?
Im not sure now what to do with it - has it already been done? - its the sae build that im running already.
Thanks.
V~ :dizzy:
headkaze:
Read it again, the line has to go before ui_display_startup_screens(). It will be there already but after line. So when you paste it before that line it should appear before and after ui_display_startup_screens().
Navigation
[0] Message Index
[*] Previous page
Go to full version
