Main > Woodworking
waterdamage. Salvagable?
johnvv:
See the 'stickied' thread
Water Damage base repair - Generic BnB cabinet
in this forum (look near the top of the current message list). It show and example of removing bad wood, replacing it, and then using bondo to cover the work. From there you can prime and paint.
leapinlew:
--- Quote from: F_Zero45 on January 07, 2007, 08:41:40 pm ---what would you use to 'glue' the replacement pieces back to the cabinet? I mean, so that it doesn't look like it was all 'chopped up' ? wood glue and bondo? :P
:dunno
The side should be held on with blocks and screws (staples). It'll come apart with some work. Put it back together the same way.
