Main > Woodworking
Casters on cabinets - stability?
Pages: << < (3/3)
NightGod:
--- Quote from: Brumaz on December 27, 2006, 03:38:35 am ---My cab in the making is very sturdy on casters, with lockable revolving ones at the front, and fixed at the back. Buy ones that are combined rated high enough for the finnished weight of the cab
I did the same thing-stability has never been an issue. If you want them hidden, it's easy enough to do what I did and recess the bottom enough so that the outer panels are only a 1/4" or so off the floor.
fjl:
--- Quote from: deadkenndys1105 on December 23, 2006, 02:01:00 am ---One my millipede cabinet there set up were you have to tilt the cabinet back so the wheels touch the ground.  Its kinda weird the first time you do it but its not to bad after a while.
Can I see pictures of how you did this?
FrizzleFried:
Call me cheap...I use a hand-truck that is in the next room over.   Works perfectly fine...
ChadTower:
Me too, but for pins I use a set of four furniture movers with casters on them.
Pages: << < (3/3)
Go to full version
