Main > Main Forum
How do I get +5 Volt power source, I'm a noob in this area, any advice?
postalp123:
Thanks Kay for the reply,
Funny you mentioned this, because I was actually under the desk with my multimeter between posts and came to the same conclusion (Red = 5 Volts).
Good stuff!
JoyMonkey:
The pin header on the IPac has two +5v pins:
http://ultimarc.com/ipac2.html
postalp123:
--- Quote from: JoyMonkey on December 11, 2006, 01:24:09 pm ---The pin header on the IPac has two +5v pins:
Thats for an IPAC-2, you think that would matter?
Scumgriever:
--- Quote from: Kaytrim on December 11, 2006, 01:00:17 pm ---Yellow +12v
Black 12v Ground
Black 5v Ground
Red +5v
Just as a side note.
This has always thrown me... Whay would they put the lower voltage on the red wire with the higher on the yellow.
I know its been that way for donkeys years but it just seems so counter intuitive. :dunno
fatfingers:
--- Quote from: postalp123 on December 11, 2006, 12:48:01 pm ---Thanks for the reply fatty (and I mean that in the most respectful sense ;D ) I dont have my IPac-4 sitting here in front of me, but looking at this pic, I cant seem to find the 5 volt lead on it:
If you can locate it on there, let me know, thanks!
*sigh* It seems you are correct and I'm an idiot! :hissy: I usually try not to post when I'm not certain, but I thought I was in this case. It seems the IPAC/4 must get power from the PS2 connector. I think that means you're back to the drive connector (red).
Navigation
[0] Message Index
[*] Previous page
Go to full version
