Main > Software Forum
Alpha Transparency in AtomicFE or any other Front End
<< < (4/4)
youki:
Hi,
Back from vacation.   So , Atomic 0.18 won't solve that problem yet.
Routine (gradual transparency mask) to do what you want are implemented in 0.18 but won't be accessible  to user yet , will be in 0.19 , i still have some improvement  and bug fix to do on that side.
Anyway that routine requires a good processor to have good response time (directly linked to the size of the surface where you are applying gradual alpha) . (i' d said for the surface you want , you wil need at least a 1.5ghz processor).
I will be happy to provide you same beta version of the 0.19 (when i will have some)  if you want test that part.
AllisterFiend:
--- Quote from: youki on October 07, 2006, 10:08:34 am ---I will be happy to provide you same beta version of the 0.19 (when i will have some)  if you want test that part.
Yes, That would be great.
Thank You Youki.
Allister Fiend
Navigation
[0] Message Index
[*] Previous page
Go to full version
