Main > Main Forum
2.25" trackball mounting plate, is Happ=Ultimarc=Suzo ??
<< < (2/2)
Kevin Mullins:
Is it one of these you were looking for?
(Happs dimensions)
Mounting Plate
http://www.happcontrols.com/trackballs/56553000x.htm
Mounting Kits
http://www.happcontrols.com/trackballs/55110100m.htm
Level42:
--- Quote from: Kevin Mullins on August 14, 2006, 04:00:42 pm ---Is it one of these you were looking for?
(Happs dimensions)
Mounting Plate
Mounting Kits
Thanks Kevin,
I was stupid enough only to look at the mounting view of the KIT on Happ's site, which doesn't give the dimensions between the mounting holes. The dimenions of the PLATE confirm what I already found out: it's at least the same sizes for the holes. N=1,75" and the size I mentioned (top-top)= 2x N, so 2 x 1,75= 3,5" .....exactly what I mentioned.
So, now I have this confirmed two ways, I think it's safe the Happ plate (kit) will fit the Suzo.....
divemaster127:
yes, the happ will fit these tb's, I sell these in my buy/sell thread if you need
thanks
dm
AndyWarne:
The only issue is that the pillars which fit into the trackball mounting holes are a very tight fit on the Happ plate. You will need to press the trackball very hard onto the plate to get the pillars to go right into the holes. But it should just about fit. The plates which we sell are designed for the Suzo and the pillars are slightly thinner.
Andy
Level42:
Thanks for that info Andy, I was already wondering if yours was actualy a Happs. The strange thing is.........I don't find the Suzo plate anywhere in Suzo's catalogue.....?
Navigation
[0] Message Index
[*] Previous page
Go to full version
