Main > Software Forum
MameWah 1.62b10 Error on load up??
lettuce:
--- Quote from: Minwah on August 02, 2006, 07:11:04 am ---
--- Quote from: lettuce on August 01, 2006, 12:13:55 pm ---I tried that i took the ini file that mame made from the mame directory, place in in mamewah\config\mame, but i still get the same error
Don't put Mame's mame.ini in there....because that is for Mame, not Mamewah. As long as you create the \config\mame folder, Mamewah will auto-generate the ini file for you.
The config\mame folder is already there when i install mamewah? Even when i start up mamewah for the very first time after install i get the error message
Malacus:
i havent really found this anywhere else - had the problem myself and started looking around to find nothing
-open mamewah.ini
change
current_emulator
to
current_emulator mame
after that, i cant seem to generate a rom list...
sorry for bumping and old one...
Banacek:
try upzipping the file with either Winzip or XP's built in zip interface. I had the same error, but I used WinRar to unzip the file. After I used XP, it worked fine.
peanut:
i also have this error on a clean install of mamewah, and nothing seems to fix it
Minwah:
--- Quote from: Banacek on August 16, 2006, 08:12:20 pm ---try upzipping the file with either Winzip or XP's built in zip interface. I had the same error, but I used WinRar to unzip the file. After I used XP, it worked fine.
I would definately recommend using WinZip to unzip my downloads...several people have had problems when using WinRAR.
I can only suggest try v1.62b11 when it arrives....I keep saying this but it should be very soon now...
Navigation
[0] Message Index
[*] Previous page
Go to full version
