Main > Software Forum
PSX games that don't use analog stick...
<< < (3/3)
loadman:
--- Quote from: vulcanfk on July 23, 2006, 08:14:16 am ---
--- Quote from: loadman on July 23, 2006, 03:55:47 am ---My Question is:
What 'command line' to you use to launch a game on ePSXe from a command prompt?
c:\epsxe\epsxe.exe -nogui -loadbin "[rompath]\[name].[romext]"
Thanks   ;)
Howard_Casto:
--- Quote from: Space Fractal / Denmark on July 23, 2006, 04:32:37 pm ---If you have a access to a light gun, and can get it to run with it (No, I dosen
Banacek:
--- Quote from: TalkingOctopus on July 23, 2006, 03:32:02 am ---Here are the ps1 games I play on my arcade:
Raiden Project  (Includes Raiden 2, which to my knowledge does not work in MAME, but my knowledge is really out of date)
Raiden DX (JPN)
Gradius Gaiden (JPN)
Raystorm
Ray Crisis
Thunder Force V
Einhander
R-Type Delta
G-Darius
Harmful Park (JPN)
Zanac X Zanac (JPN)
So uh...if you don't like shooters, you can probably pass on the ps1.  Also, I use a real ps1.  I have no idea how many of these work under an emulator.
R-Type Delta and Einhander are MUST HAVE PSX games. (that is, if you like that sort of game :) )
Space Fractal:
--- Quote from: Howard_Casto on July 23, 2006, 08:09:52 pm ---
Circo:
I've had trouble with those two.  I think it's because I don't rip my own discs, but regardless there's some kind of issue getting certain versions of those two games running on epsxe.  Light gun support is supposed to work well with the emulator though, so if you can get those two to run then I reccomend them myself.
You might try PSX 1.7 http://psxemulator.gazaxian.com/
I have not checked compatability past "D" but it seems to be around 80% compatible.  No extra plug-ins or speed up slow down modes, it just works.  It does use software instead of hardware rendering and it seems very cab friendly.  I am currently using it to make the EmuMovies PS1 Set and I have been very happy with it.  It also uses a .cdz format which compresses your bin/cue or ccd/cue files which, on average reduced file sizes by 30%.
Navigation
[0] Message Index
[*] Previous page
Go to full version
