Main > Software Forum
ArcadeVGARes.exe is doing nothing?
Howard_Casto:
It appears to me that mala doesn't allow for custom resolutions. This is your issue as 640x480i looks like crap. Btw, if you monitor is running at 200hz then it's gonna blow up.. run! ;) The 20hz refresh rate is what makes the display viewable on an arcade monitor. I don't know a lot about avga, but see if windows allows you to use some of the custom resolutions available on the card at the desktop level... if so that'll help for the desktop at least.
swindus:
You can run MaLa in any resolution provided by your graphic card. So it is possible to run MaLa with a AVGA card in a resolution of 368x240 at 60Hz for example, thats what I'm doing on my cab. Normally all provided resolutions are listed in the combobox on the tab Loadman attached above.
MaLa behaves like any other windows program, it uses the current resolution and refresh rate of your desktop. Additional you can change your desktop resolution (not your refresh rate) with MaLa to the resolution of a fixed size layout or to any resolution provided by your graphic card.
payment_due:
Well I was finally able to get MALA to look *somewhat* nice. It's not jittery anymore so I've got that going for me.
Now I have a fuzzy vid problem with my GAMES! They aren't jittery like Windows/MALA was, but I can just tell they are a little blurry. Ive tried using AVGARes.exe (if I spelled that right) and it was working BEFORE, but now it won't process any games.
It looks like it's going to start doing it, then it automatically finishes. I'm not sure what's going on with that.
gamecreature:
Did something change in your Mame settings?
payment_due:
Not that I know of, though I did have to end up going to a regular version of MAME32Plus because WolfMAME didn't support multiple BIOS. (LAME!)
I have force aspect ratio checked, but even if I uncheck it, it doesn't affect anything, other than that - the version of MAME i have doesn't really have any options for changing things past running in a window and setting everything to auto.
I know it's something having to do with my ArcadeVGARes.exe tool, I dont know why its not working.
Navigation
[0] Message Index
[*] Previous page
Go to full version
