Main > Software Forum
MAMEWAH and Future Pinball
<< < (3/5) > >>
Space Fractal:
If you change ESC for all emulators, if may been better to use autohotkey to press that key for you.
Install Autohotkey, and use a script loke this:
--- Code: ---#NoTrayIcon
#SingleInstance force
return
; ESCAPE
Joy26::
Send {ESC down}
KeyWait Joy26
Send {ESC up}
return
--- End code ---
Joy26 is the button or key, you would change to.
If it only in MAME, you can press TAB to pop the menu, and you can chage the ESC key in here (if remember corret, it under general config or such).
Czapala:
How does it look on an Arcade monitor?
i.e. a 27" Multisync Betson with max res of 800X600
Space Fractal:
A Lots better than Visual Pinball, that never looked very good in 640x480, since it screamed for a 1024x768 resoulution. I did this to work on my cab, but I scraped it again, because it was to hard to see anything, when it was in interlace mode.
In Future Pinball, there are some camera view, that have a lots closer view on the table, wich mean you can see more. Since it 3D, you select more than one camera view, and it look very fantactic. It even in a "crappy" 640x480. It a good thing.
The only bad thing is, you can
Howard_Casto:
I just wish we could convince black to get some dual screen support in there.  Where it's 3d, it is begging to have an extra render target aimed at the blackglass on a seperate monitor.
Space Fractal:
Yeah, this would been very good. This should been request into thier forum. It should not have some big trouble to add a another camera and set it to a given XY place (even it may been slowdown on some computers).
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
