Author Topic: MameWah 1.61 and Mame 106-106u11 not working (explanation)  (Read 1680 times)
Cananas
  • Last login:August 27, 2017, 07:39:03 am
  • and the seventh day... PacMan was created
« on: June 04, 2006, 11:17:37 am »
It seems that the new version of mame has a bug in the command line parser, so that if you try to run a game with its name in Uppercase you get an error.
So,
mame -OPWOLF -> Error   EDIT: Fixed in 106u4, but doesn't load
mame -opwolf -> run OK
BTW I don't know what is the reason Mamewah writes the name of the rom in uppercase.
EDIT: Put in the subject the version of Mamewah that don't work with the lastest version of Mame (even 107, I presume.)
« Last Edit: July 13, 2006, 02:21:02 pm by Cananas »
  • Last login:May 03, 2024, 11:58:33 pm
Re: MameWah and Mame 106u3 not working (explanation)
« Reply #1 on: June 04, 2006, 03:06:20 pm »
actually the bug is that it ever allowed it the other way.
command-line options are supposed to be case-sensitive in a multi-platform app.
You shouldn't really be running 106u3 anyway.  MAJOR core changes... it won't be bug free again until .107  Stick to .106
Cananas
« Reply #2 on: June 04, 2006, 03:18:41 pm »
Yes, they are. The nearby rom search engine is broken in this version. It is known bug. It is not only the conversion to lower case. This a problem for the people that they want to test the last version and use Mamewah, because only roms like 1942, 1943 (roms with numbers only) will load.
Yes, but someone must test those changes....
« Last Edit: June 04, 2006, 04:32:07 pm by Cananas »
« Reply #3 on: June 05, 2006, 03:23:41 am »
I mean no offense but you don't install a test build of mame with a fe, you run it from the command line.  If you can't run from the command line then you probably aren't qualified to do debugging for the mame team anyway.
It's good that you posted this, but I don't think it's relavant info until .107 comes out.  As aaron himself said, don't run these builds and expect them to work correctly.
The upper/lower conversion is part of the "fuzzy logic system" that also handles the rom searching and the "best match" stuff.  All that code has to be re-written before stuff will work again.
Cananas
« Reply #4 on: June 05, 2006, 05:04:47 am »
You don't want understand... Try to test all mame games typing the rom name in the command line to test if the new render engine works with all of them!!!! Oh, sorry, I forget that you can't think  more than a one year old kid (Don't offense, please).
Why don't you try to help? Any problem? Oh, sorry again. I forgot that you are too busy debugging your  :censored: programs.
Aaron requested people to test the changes. Of course you are not part of this people. Sit on your chair and wait to the 107. In my town this is called egoism. Others like me want to help to MameDevs.
But after release 107, please be quiet.
Ooooh, do you think I didn't know that?. You're my man, Howard. Really. :applaud:
What can we do without your invaluable help, Howard?
Like I said before (in another topics), If you don't want to help, don't do it. But then, be quiet, please.
Cananas
« Reply #5 on: June 06, 2006, 01:29:02 am »
I will try to re-do the question:
Why does Mamewah write the name of the rom in uppercase when launch mame? In uppercase the rom doesn't load.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #6 on: June 06, 2006, 02:03:32 pm »
Did you ask over at the mamewah forum at www.mameworld.info ?
« Reply #7 on: June 07, 2006, 05:19:50 am »
It's good that you posted this, but I don't think it's relevant info until .107 comes out.  As Aaron himself said, don't run these builds and expect them to work correctly.
What in the blue hell is your major malfunction?
I test for game problems myself and yes I do manually type the rom names from the command line.  Why?  Well it's common sense when you are debugging a program to eliminate any other possible causes for bugs.  I.E. you don't use a fe to debug mame, because as you discovered often the bug isn't even in the emu.  Let me know if I'm making too much sense for you and I'll give you bad advice insted.
Aaron requested fro everyone to check for errors in MAME, not mamewah.  He didn't suggest you complain but mamewah not working on a test build that isn't even working yet.  As I said, just wait till .107 and it'll work again.  Use the command line to debug, as I said, that is the proper way to do it.  If you are too lazy to type the rom name you can just drag-n-drop.  Pitiful excuse on your part man, just pitiful.
I WAS being helpful.  The problem with some people on this board (look in the mirror) is they only consider a response "helpful" if someone tailors to their every whim or gives them the answer they were expecting in the first place. Don't shoot the messenger, I just told you exactly what Arron or any of the mame devs would have told you given the post you made, namely don't debug with a fe because it adds in extra variables to worry about and don't complain about fe-related issues on a test build because it would waste the time of both the fe author and fe devs to look into something that very well might be fixed in the next official build.  Your problem is this issue effects you personally, so you want it fixed yesterday. Who cares if it means poor minwah has to re-write his code just so you can test .106u3 through .106u6 or whenever it gets fixed as long as you can save yourself three keystrokes from using the command line.
Like it or not, the best advice a person could have given you was to be patient.  Apparently patience isn't a virtue you possess.
Should minwah look into this?  Sure he should, it's bad coding practice to spit out the command line in all caps,  BUT  the way you went about bringing it up didn't sound very selfless at all.  It sounded to me like you could care less, but now that it is a inconvenience to YOU that it should be fixed immediately.
In conclusion I don't know what in the world crawled up your butt but you owe me an apology.  I didn't say a single thing offsense, but of course as YOU can't think beyond the level of a one year old kid (nice grammar btw)  you took it that way because I suppose you are insecure about yourself or something, I really don't know.
See I'm being offensive now. You want to act a jerk well I can do that too.  Get over yourself.  My advice is free, if you don't like it just ignore it.  I love how people quote one tiny little half a sentence comment that I make, a generalized comment that is NEVER directed towards them in any way and rant for a page or so about how rude and childish I am.  You guys have issues, I mean it.  I feel bad for you really.  I don't understand how a rational human being can get so upset over a tiny little harmless sentence.  Are you lonely?  Do you have a fear of rejection?  What?  I don't get it. I never take the low roads in these kind of discussions, but this time I am genuinely offended so I'll stop trying to be civil and just throw it all out there.
What did I ever do to you except do what no one around here has the balls to do but me, namely give an uncensored, unbiased, non-sugar-coated opinion?
So, in the immortal words of George Carlin  :censored:
And I apologize to anyone except cananas who happens to run across this thread.  I think it's silly to insult people on messageboards but if someone disrespects me this badly in a public forum I'll sure as hell finish it.
Cananas
« Reply #8 on: June 07, 2006, 10:20:31 am »
 :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah:
You can continue...
but if you want to help, read the topic again and think your answers before writting them. Right?
MKChamp
  • Last login:February 07, 2024, 02:45:53 pm
  • Stil around.
« Reply #9 on: July 10, 2006, 05:08:15 pm »
I looked over at the MAMEWAH forum and didn't see any mention of this. Looks like this board gets more action...and responses...so...
Is this an issue that your looking at Minwah?
« Reply #10 on: July 13, 2006, 11:32:22 am »
No it is not, because I addressed it last August ;)  From what's new:
MAMEWAH v1.62b1 (03/08/05)
Romnames are now always sent in lowercase for maximum emulator compatibility
FWIW I dunno why I sent the romnames in caps originally, I think just because my backend (!) dealt with the romnames in upper case.  Use the latest beta and all should work fine :)
MKChamp
  • Stil around.
« Reply #11 on: July 13, 2006, 12:20:49 pm »
Ahhh...that explains why no one said anything in the beta testing thread....
I appreciate your response...and more importantly...your app! Thank you very much...I'll fed-ex you some beer!
Havok
  • Trade Count: (+17)
« Reply #12 on: July 13, 2006, 01:07:45 pm »
Great! It will be nice and warm, just the way those Brits like it...
 :laugh:
