Main > Main Forum
Trackball wiring help.
Kremmit:
The trackball will not use the Z-axis unless you intentionally wire to the z-axis pins on the Opti-Wiz. I would reccomend not doing this, as the Z-axis is read differently by Windows than the other two axes. If the sensetivity for both axes on your trackball don't match (and they won't if you use the Z axis), then your cursor will not go where you try to move it.
The z-axis is best for a spinner, steering wheel, optical rotary joy, or other single-axis optical device.
blue:
OK, i just got home and am looking at my trackball.
There are 8 wires.
2 red
2 black
1 Brown
1 Blue
1 Green
1 Yellow
And all the infor i've found and have only have 6 wires. So which is which? ???
Are the extra red/black just the another +/- for the ground and 5V??
That being the case is the correct molex wiring...
blk - grn
blk - red
red - blu
ylw - brn
Or do i just double up on the red and black??
blue:
Does anyone know that answer to this?
And to you know if there are different types of 6-pin molex??
I'm going out at lunch and just wanted to confrim.
thanks.
u_rebelscum:
--- Quote from: blue on May 15, 2006, 09:46:37 pm ---OK, i just got home and am looking at my trackball.
There are 8 wires.
2 red
2 black
Double up the red and black. There are two boards, one for each axis. If you follow the wires into the TB, each board gets a red and a black for power and ground.
Kremmit:
Yup, double-up the ground and +5v.
There are different kinds of 6-pin molex, in that there are different sizes. You want .093 size terminals, not .062, which is the other size my local electronics store carries. If you're going to Radio Shack, they have them in the slide-out bins in back, and are labeled as "Power Connectors", with molex written in really tiny type. The sales idiots had no idea what I was talking about when I said Molex. The "Female" connector is the one that the trackball plugs into, the "Male" connector is the one that comes pre-wired on the trackball. This can be confusing, because the shape of the plugs is backwards to what you would expect from male and female. That's because the pins are what they use to determine the male/female-ness of the connector, not the shape of the plastic housing.
Navigation
[0] Message Index
[*] Previous page
Go to full version
