Main > Software Forum
Frontend: What am I doing wrong? AtomicFE and Mala
<< < (2/2)
xteeejx:
Hi Youki,
My roms are all in one folder, but my CHDs are all in seperate folders, I don't know if that matters or not.  Should I put them all in the roms folder?  And My snaps are in different folders, but that's not difficult to fix.
My main problem now is trying to setup the multiconfig.  I followed the intructions but it doesn't seem to be working.  After running the multiconfig I still only see the arcades menu not any of the genre menus I set up in the multiconfig.  Do I need to do something different since I have the AngelscryArcades plugnplay installed?
Do I need to modify a file to point to the muliconfig files?  I feel like there's some basic part of this, I'm not understanding  ;)
-TJ
youki:
Hi,
When you are using a Plug'n play module  (when at least one plug'n play is activated) Atomic is in Plug'n Play mode.
It means it will only load module activated in the PlugnPlay manager other config file will be ignored.
But there 2 solutions :
1- the first one you disable all plug'n play module with the PlugnplayManager.exe  , in that case Atomic will run the normal configuration you defined as start up config.
2- Using the plugnplay manager , you can add your own config file to the  Module list.
If you used the multiconf wizard to create your config , you will have to add the Main.Cfg file in the module list.
But if what you are trying to do is to modify the module arcade to have the category list , it is different. Module haven't be designed to be modified in they structure, but of it is doable.  Using the multiconf wizard you can generate your config based on the Arcade.cfg file ,  then you can edit the file Arcade.pnp (in the PlugnPlay folder) to make it point to the Main.cfg you just generated. It should work.
xteeejx:
Cool, I got it working thanks!  I used the multiconfig to create the config files from the arcades.cfg, then switched the arcades.cfg to be a cfg loader.  Piece of cake!
Now if I could just figure out my monitor's vertical scrolling problem, I'd be good to go!
Thanks a lot!
-TJ
youki:
Cool.
For you monitor problem. If your image scroll vertically i think you just have to move the VSync potentiometer (variable resistor)  (that should be somewhere in your cab) until the scroll stop.
xteeejx:
Hey Youki,
I didn't see your reply until just now.  Thanks, yeah the vsync works for about half of the games but a lot of the vertical games and mortal kombat games etc. won't without adjusting every time.  I'm still trying to figure out a soultion, but I know it doesn't have anything to do with the font end.
Navigation
[0] Message Index
[*] Previous page
Go to full version
