Main > Software Forum
GBA Screenshot Pack
jcrouse:
There is also a dedicated GBA renamer here: http://www.gba-renamer.com/
John
jcrouse:
--- Quote from: headkaze on March 31, 2006, 12:45:07 pm ---heh quite amusing, I use the same util myself ;)
Headkaze......Check your PM's.
John
jcrouse:
--- Quote from: headkaze on March 31, 2006, 09:25:59 am ---Hey jcrouse perhaps you could add the official Pocketheaven dat file instead of the one included with your GBA Image Renamer app. It does use a nicer looking naming convention.
And maybe one more request :) maybe you could add a browse button to the ROM folder, and a tickbox saying "remove numbers" that will after renaming the snaps rename the ROMs and snaps removing the numbers at the start. Would just be more cab friendly I expect.
Since the images are from the Advance-Power website I will be using their DAT file. The images do not match the DAT files from PocketHeaven.
I will look into stripping the numbers from the rom images although, as previously stated, it is quite easy using BRU.
More later,
John
jcrouse:
--- Quote from: jcrouse on March 31, 2006, 12:46:28 pm ---There is also a dedicated GBA renamer here: http://www.gba-renamer.com/
John
FYI....The dat files for this utility seem to match PocketHeaven and not Advance-Power which controls the images names so I will be adding the rom renaming to my utility. It will be ready in a few days.
John
headkaze:
Thanks jcrouse! Didn't realise the numbering system was different too, so you can't just use the Pocketheaven CLRMame dat file with your program. Oh well, looks like it will have to be the advance-power naming convention. I guess if you end up adding the number stripping to your program you could also get it to strip the stuff between brackets at the end of ROM name.
Navigation
[0] Message Index
[*] Previous page
Go to full version
