Main > Software Forum
Mapping ZINC controls...
<< < (3/6) > >>
JCKnife:
I'm having a similar problem: got the fighting games and xevious working but can't get Monster Farm Jump to recognize a button. This FE has no documentation and a horrible gui. I'm stuck.
joe jet:
I asked this question a while back and never got an answer...
http://forum.arcadecontrols.com/index.php?topic=47008.0
The issue here is, you use Aldo's FE to map the controlls, but then when you run Mamewah, the control settings no longer work.  Specifically - all i want is street fighter EX (to start with) and if you launch using mamewah (using minwah's suggestion on the mameworld.net forums) and Howard's wrapper, either the .cfg file is not loaded, or it is not recognizing it.....
I understand this should NOT be a FE issue, but that being said, if the .cfg works with Aldo's FE and Mamewah is simply loading zinc with with its default settings (that i assume Aldo's FE writes to .cfg file) it should work like every other one on my cab but it doesnt.
I assumed that zinc uses a different .cfg file by default or none at all and therefore the .cfg file is for aldo's FE only...
But i dont know since i have scoured these forums and others and cant find an aswer.   :'(
JCKnife:
I have to disagree with you joe jet, I'm configuring in the Aldo front end and launching from Mamewah and the changes I'm making ARE showing up just fine. Street fighter, Tekken are fine and after some trial-and-error, Xevious 3d is fine. I just can't find a way to make Monster Farm Jump recognize a button. It doesn't help that Aldo's button names are all "punch" and "kick" varieties instead of "button 1, button 2, etc"
surf:
Even loading with Aldo's front end, some games do not work...
If it helps, my setup
   up           L ctrl    L alt   space                                       r         a       s       q
left right        d     g
  down       L shift    z         x                                            f         w       l        k
               c        v
Think joystick, then buttons...
I know there are great minds out here...help!
joe jet:
Well Surf is having the same problem i am having with Street fighter, so it is either a bug or has to do with the sequence of installation i chose...
I was going to wipe it out and reinstall, but i never even got an answer to my question about what/where the actual .cfg file is located (yes i know there is a control.cfg or something in the root but ther are also other game .cfgs elsewhere) and i got discouraged.  Seeing others with the same problem at least lets me know i am not a total Noob   :angel:
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
