Main > Main Forum
Can someone confirm that the 49way hangs 5" deep under CP?
squirrellydw:
I am building a 3 sided cocktail table and I am thinking of using two of these on the third panel, how would I hook these up? I was going to use an iPac4 for all the joysticks and buttons. Does the wiz49 get connect to this or does it connect separately? I am going to install an optipac also.
Timoe:
In order to get all the features I mentioned from the 49way stick you will need (1) GPwiz49 encoder for each 49way stick.
The good thing here is that the GPwiz offer 23 additional inputs so you should have more than enough inputs for all your buttons and joysticks.
You wont need an IPAC then.
squirrellydw:
So I can hook another joystick up to it, say a 4 or 8way?
Timoe:
After you hook up your 49way stick to your GPwiz49 you will still have 23 inputs available ON EACH ENCODER. That'll be more than enough.
markrvp:
--- Quote from: squirrellydw on February 25, 2006, 07:43:30 am ---So I can hook another joystick up to it, say a 4 or 8way?
Yes, any of the 23 inputs can be used for joysticks and/or buttons. I have the second joystick connected to inputs 8, 9, 10, 11.
Navigation
[0] Message Index
[*] Previous page
Go to full version
