Main > Main Forum
Diagrams/dimentions
Seven7:
ANY diagrams or messurments are fine. And yeah, i know a wood candy cab is strange, i don't pretend to be normal. But i don't have the celing hight for a standard cab, so this is good. That, and i like sitting down. It"ll be a coustom job with a 20" tv. It will be very strange, however it will work for me. Anything will be much appreciated. (for anything above a 20" Ill modify the monitor housing area. and yeah, the lowboy is a cool cab, I'd prefer a candy though. At this point iam canda desperet. So much in fact, i can't spell ;D
-Seven7-
grueinthebox:
The bottom of the control panel is 23" from the ground in the front, 21" at the back. Top is 26". The machine is 36" deep overall, excluding the bulge at the back for the monitor chassis. The machine is overall 56.5" high.
Holler if there are any other specifics you need...
Seven7:
Pics? (sorry, i don't think i understand exactly what your saying, i want to be sure)
thanks
-Seven7-
grueinthebox:
Will take some pics that explain better when I get home from work.
grueinthebox:
VERY crude, but hopefully it gets the point across... You can see in the picture that the bottom side of the control panel is angled, and is higher in the front than in the back where it meets the machine.
Navigation
[0] Message Index
[*] Previous page
Go to full version
