Arcade Collecting > Miscellaneous Arcade Talk
MVS Question
<< < (2/3) > >>
Goz:
MVS is a variation of the JAMMA std.
If you have a JAMMA cab you simply plug it in and  make one wire modification. Sites like HARD MVS previously mentioned have info on this.
-Goz
Stingray:
--- Quote from: ArcadeNoob on July 10, 2005, 03:40:10 am ---Thanks a bunch!
So...........you think I should buy one of these bad boys?  How many games are available, and when was it first realeased?  Also, are they still making games for it?
Yes you should buy one, mine gets as much or more play than my MAME cab. There are a ton of games available for it. I don't believe that new games are still being commercially produced, but there are a ton of them out there.
-S
ArcadeNoob:
The games can be picked up fairly cheaply as well, correct?
Also, do all the games use the same standard control panel?  In other words, is it kind of like a console, where you just "plug and play"?
Goz:
--- Quote from: ArcadeNoob on July 18, 2005, 11:22:17 am ---The games can be picked up fairly cheaply as well, correct?
The NEO GEO has a huge following and as such there are varying degree's on cost of a CART. A Full kit (original box, art, cart, etc) typically is $100+ and loose MVS cart depending on game can run from $10 - $100 with the majority being sub $50 range.
-Goz
Stingray:
Pretty much the same type of pricing variations you see with JAMMA boards, and for similar reasons.
-S
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
