Arcade Collecting > Miscellaneous Arcade Talk
Anyone have a Q*Bert upright or Midway Mini Cabaret cabinet?
RayB:
Satan's Hollow MINI?!?! Wow. That must be rare. Please share photos with us!
MonitorGuru:
--- Quote from: RayB on July 04, 2005, 10:57:17 am ---Satan's Hollow MINI?!?! Wow. That must be rare. Please share photos with us!
Yes, here is a site with a couple pics: (down when I posted this but was up last week):
http://www.tutankham.com/satan/satan.htm
And here was a recent one on eBay:
http://images.andale.com/img/imageTemplate.html?img=http%3A%2F%2Fimages.andale.com%2Ff2%2F115%2F106%2F3610162%2F1117793377230_Satan_Fr2.jpg
http://images.andale.com/img/imageTemplate.html?img=http%3A%2F%2Fimages.andale.com%2Ff2%2F115%2F106%2F3610162%2F1118389202953_Satan_Fr.jpg
http://images.andale.com/img/imageTemplate.html?img=http%3A%2F%2Fimages.andale.com%2Ff2%2F115%2F106%2F3610162%2F1116078075461_Satan_Bz.jpg
http://images.andale.com/img/imageTemplate.html?img=http%3A%2F%2Fimages.andale.com%2Ff2%2F115%2F106%2F3610162%2F1116639035865_Satan_Cp.jpg
http://images.andale.com/img/imageTemplate.html?img=http%3A%2F%2Fimages.andale.com%2Ff2%2F115%2F106%2F3610162%2F1119192825402_Satan_Mq.jpg
http://images.andale.com/img/imageTemplate.html?img=http%3A%2F%2Fimages.andale.com%2Ff2%2F115%2F106%2F3610162%2F1119216731253_Satan_Sd2.jpg
http://images.andale.com/img/imageTemplate.html?img=http%3A%2F%2Fimages.andale.com%2Ff2%2F115%2F106%2F3610162%2F1118889387477_Satan_Sd.jpg
MonitorGuru:
Hi. Thanks again for the detailed measurements. I have most of them transfered to my side and have a few more questions to finish :)
1) Is the black holder for the glass perpendicular to the glass (titled with relation to the back wall) or is it parallel to the back?
2) I assume there is a board behind it that it screws into.. perhaps to answer question 1, the easiest is to measure the height of the board and then the indentation from the back of the cabinet at the top back of the board and at the bottom back of the board. (like we did the tiny piece between the glass and speaker board)
3) With the control panel off, how high is the front piece from the absolute outside bottom? Is it flat on top where the control panel rests?
4) How far off the outside bottom is the outside bottom edge of the coin door frame?
5) Speaker positioning: How far from the back tiny board do they speaker bezels start and how from from the plastic lip of the marquee? How far are they in from the sides, and how far apart are they? (I assume they're 2x 6x9's not 4" squares)
6) How much play is there (guestimate?) on the glass bezel into the slot on the back board and under the front black lip? I guess 1/8"
7) How tall is the fixed back piece on the lower back side of the cabinet (below the removable door)?
8) How tall is the back door? (I think I have both of these correctly figured based on the scan from the manual, but wanted to double check) I think there is a fixed 3/4" tall piece on top just before the top board on the cabinet as well, right?
9) If you have time, if you can give me the offsets of the air holes from the edges on the fixed bottom piece and the removable door, that would be nice. I do not need exact, just within an 1/8" on them.
gotstik:
"have most of them transfered to my side and have a few more questions to finish"
Try these!>
** Not sure if I understood this one, but here goes;
~~A) If it
gotstik:
Sure thing! I have the CP all apart right now, but I'll try and get it back together and snap some pics for ya!
You are right about rare... It has been next to impossible to find parts.. Gotta be patient in this hobby thats for sure.. ::)
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
