Software Support > DOS/WinCab
Wincab skins questions
<< < (2/2)
pacman:
Hi Chris,
I have tried to play with settings as per your suggestions and now I can have something more readable but the thing is that song name is not fully displayed when too long;
I would suggest to do also a cd2-1 skin which would allow a better display for low resolution arcade monitor (640x480 and lower)...
Chris:
--- Quote from: pacman on June 21, 2005, 03:29:20 pm ---Hi Chris,
Yeah, I need to create lots and lots more skins...
A cd2-1.skn would look almost exactly like cd4-1.skn, except for these changes:
In [Titlestrips]:
Width=987
In [StripGrid]:
cols=1
That should be all you need to convert it to a two-album display with a really wide song title area.  (This is off the top of my head; I haven't tested it.)
--Chris
pacman:
Hi Chris,
Could you please specify where [StripeGrid] is located in the skn file as I do not find him ??? ???
Chris:
--- Quote from: pacman on June 22, 2005, 04:27:13 am ---Hi Chris,
It's [StripGrid], not [StripeGrid].  It's the section right after [Titlestrips], and just before all the icons. The whole StripGrid section looks like this:
[StripGrid]
x=18
y=21
rows=2
cols=2
rowspace=7
colspace=27
CoverArtSide=Left
CoverArtSpace=4
So 2 rows and 2 columns make up the 4 albums you see; you're reducing this to 2 rows in 1 column.  rowspace and colspace are the size of the gap between rows and columns, CoverArtSide is which side of the titlecard/art pair the album art appears on, and CoverArtSpace is the gap between the art and the title card.
--Chris
pacman:
Hi Chris,
Ooopps sorry OK I figured it out now.... :P :P :P I will give it a try this evening and let you know then ;) ;)
Thanks for your help!
Navigation
[0] Message Index
[*] Previous page
Go to full version
