Main > Main Forum
Can you change the led bulb or color on the IPAC LED Harness?
<< < (2/2)
chrisindfw:
Actually not. I just got my harness in the mail. You can simply pull off the LED from the connector and then add a new one. Just make sure you know which is the + and -.
Timoe:
What type LED is it?  Andy from Ultimarc mentioned something about an internal resistor.  Has anyone here tried this?
Part of me wants this harness just for the conical led holder.
Anyway if anyone can help me with where to find this type LED that would be great.
Tiger-Heli:
--- Quote from: timoe on June 04, 2005, 05:57:38 pm ---What type LED is it?  Andy from Ultimarc mentioned something about an internal resistor.  Has anyone here tried this?
I think he means the resistor is internal to the harness, but you could try a 2.1V LED, worst case is it will burn out too quickly.  That or chrisindfw might have more info.
RandyT:
Be careful what you do there.  Contact Ultimarc to find out what the LED voltage and resistor values are.
Unless you use a driver board like the one from Gamecab, you will be driving the LED directly from the microcontroller.
And you really don't want to pull too much current through the microcontroller.
RandyT
Timoe:
Maybe if GroovyGameGear could sell me a Blue Versa Ball replacement stick for my Happ supers I wouldn't need no stinkin lights.
Navigation
[0] Message Index
[*] Previous page
Go to full version
