Arcade Collecting > Miscellaneous Arcade Talk
Galaga help
dabone:
Those custom IC's corrode ALOT..
I work on a galaga for a local pizza place, and get a call on it around once ever 6 months, usually the same thing, random lock up, reboots, etc.
Clean/Reseat the custom chips usually clears everything up for 6 more months or so.
(The sad part is they have 5 games at that location, and the galaga out earns the other 4 put together.)
(The other games are a golden tee golf, ms pac, wrestlefest, Mechanized Attack.)
Later,
dabone
SuperGunGuru:
Here's something else you can look into. Randy Fromm has a cool tutorial on troubleshooting input failures. I have a Simpsons PCB that thinks the player 2 coin mech is constantly active. Using Randy's article, I've found the defective IC and now need to find the replacement.
http://slot-tech-ftp.serveftp.com:8080/technical_department/general%20electronics/do%20it%20yourself%20PCB%20repair/do%20it%20yourself%20PCB%20repair.htm
Stingray:
--- Quote from: dabone on May 08, 2005, 09:10:28 pm ---Those custom IC's corrode ALOT..
If you put a thin coating of dielectric grease on the IC legs before you reseated them, wouldn't that help prevent corrosion? Just a thought.
-S
DaveDog:
Great info guys, Thanks!
I have two galaga boards.
Navigation
[0] Message Index
[*] Previous page
Go to full version
