Arcade Collecting > Miscellaneous Arcade Talk
What's a better joy? The T-Stick or the T-Stick plus?
<< < (4/4)
Shape D.:
--- Quote from: 2PacMan on April 27, 2005, 12:43:29 pm ---How is the functionality of the T-stick plus.  Is it really as easy to switch from 4-8 as the website says?  Do you even accidentally switch it as your playing??  Seems like that'd be the way to go so you wouldn't have to open up your control panel all the time, but i want to make sure the feel of the sticks is still good.
monkeybomb:
--- Quote from: Shape D. on May 03, 2005, 10:42:01 am ---
:P
big_garryb:
i would also add that ultimarc now have new microswitches which are quieter..... the noisy clicks always annoyed me slightly until i got right into a game.......
Kremmit:
How can we compare the T to the T+ ??
They're the same stick.  The only difference is that the T+ has had a little extra hardware attached to make the above-panel switching happen.  It's attached in places that don't have anything to do with gameplay- the extra hardware will not affect the feel of the stick or the gameplay.  You'll never know it's there except when you switch modes, and you won't ever accidentally switch modes while playing, unless you are in the habit of trying to lift & spin the machine by the stick handle while playing.  I doubt you could even tell the difference between the two by feel, unless you tried to pull them up.
Navigation
[0] Message Index
[*] Previous page
Go to full version
