Arcade Collecting > Miscellaneous Arcade Talk
Metal Control Panel stripping. (Need advice)
APFelon:
Heat guns aren't that expensive. If you are dreading grinding away at that panel, the cost of a heat gun may be worth it to you.
Something to look into, anyway.
APf
CheffoJeffo:
I had thought about the heat gun, but the kids were home before I could try it ... will give it a shot tomm.
Tks.
Arcadiac:
Hi there. Take a look at this thread, replies 24,26.
http://forum.arcadecontrols.com/index.php?board=10%3baction=display%3bthreadid=17788
I had gone thru more frustration trying to get to a bare metal control panel using all the techniques offered, wasting money on chemicals, sanding etc.
Finally someone suggested taking it to a machine shop. They baked it in the oven to burn off the crap encrusted on it and then ran it thru a machine called an abrader. I got back a clean, ready to paint or whatever cp within a few days. Look at reply #32 for a pic.
I would never try to remove any gunk from an old cp any other way again, personal preference of course.
If you decide to paint your bare cp, be sure to prime with a rustoleum type primer, let cure a day, paint a couple of coats gloss enamel and let cure a couple more days so the paint will harden.
Best of luck! ARCADIAC!
dirt:
i use industrial adhesive remover from home depot and it works very good but is really messy.
dirt
Ken Layton:
Go to the hardware store and over in the paint section buy some M.E.K. (Methyl Ethyl Ketone). It removes most control panel adheisives.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
