Author Topic: How well does Tiger Woods PGA Tour 2005 play on a MAME arcade machine?  (Read 11726 times)
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
How well does Tiger Woods PGA Tour 2005 play on a MAME arcade machine?  From what I've read, you use the mouse (eg. trackball !) to swing so the game sounds like it would be 10x better than Golden Tee Golf.  Is this true?  How well does the game play on the PC/Arcade machine?
Also, does anybody have any other recommendations for arcade/pc trackball games?
markb
  • Last login:April 30, 2011, 06:41:02 am
  • The One and Only.
Re: How well does Tiger Woods PGA Tour 2005 play on a MAME arcade machine?
« Reply #1 on: January 02, 2005, 08:24:17 pm »
I have have Tiger Woods 2004 on my cab and it does NOT play well with a trackball. I cannot achieve more than 80% on my swing no matter how fast I spin the trackball or what settings I use. I eventually resorted to the alternative swing method of button presses rather than  mouse movements.
It's a great game by the way but not for my cab unfortunately.
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
« Reply #2 on: January 02, 2005, 08:50:51 pm »
I've used 2002-2004 extensively and it works perfectly with the trackball.  100% (and more, if I overswing).  Great game for a cab!
str1der
  • Last login:March 04, 2021, 04:35:31 pm
  • Live it!
« Reply #3 on: January 02, 2005, 11:45:18 pm »
Same here. I use 2004 and it plays great. What kind of trackball are you using. I've never had a problem with swing strength.
GGKoul
  • Cheesecake Apprentice
« Reply #4 on: January 02, 2005, 11:56:31 pm »
Yep, it plays well with a trackball.
My only issue with the game is that the fonts are too small and it makes it hard to read on my Mame TV.
PaulG
  • Last login:April 10, 2007, 03:25:56 pm
« Reply #5 on: January 03, 2005, 08:15:17 am »
I also have TW2004 and a Happs Golden Tee trackball and on a normal swing, I almost always go over 100%.  In fact, not having read the instruction booklet, I sometimes wonder if this overhitting is causing any negatives in accuracy.
walls83
  • beer is good
« Reply #6 on: January 03, 2005, 08:54:17 am »
markb
  • The One and Only.
« Reply #7 on: January 03, 2005, 03:25:07 pm »
Guess I was in the minority here, so I'm going to spend a bit of time trying to get it to work now!
BuZz880
  • Last login:November 16, 2023, 02:16:43 pm
« Reply #8 on: January 03, 2005, 07:34:09 pm »
I have an arcade monitor so need the game to run at 640x480 the only Golf Game I have that can do this is Golden Tee PC which I don't much care for.  Does anyone know of a newer golf game that plays with the trackball and does run at this res?  TIA.
jcrouse
    • CPViewer
« Reply #9 on: January 04, 2005, 12:22:36 pm »
How about a couple other recommendations for PC agmes that work well with a track ball. I know the one stick exists about  PC games for a cabinet but it doesn't necessarily call out trackball games.
Thanks,
John
big daddy
  • Last login:May 01, 2019, 12:16:13 pm
« Reply #10 on: January 04, 2005, 02:25:54 pm »
count me as another one with TW2005 and it works great with the trackball. I generally hit about 90-100% and over 100% if I really spin it (and yes going over does affect your accuracy).
As someone else said, the biggest problem is the font size being hard to read (I'm running at 800x600 on a Betson Imperial 27").
As for trackball pc games, the 3 I have are golden tee pc, tiger woods 2005, and hamsterball (reviewed on retroblast site).  My daughter also plays Dora games and similar which uses the trackball as a mouse  (since she can't operate a mouse well yet it works great with the trackball...she's also gotten pretty good at hamsterball)  :)
GGKoul
« Reply #11 on: January 04, 2005, 02:43:22 pm »
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« Reply #12 on: January 04, 2005, 04:22:51 pm »
meh, golden tee pc is by far the best golf game for a cab.  i have TW 2004 and its okay, but the feel of the trackball, and the feeling that me hitting the trackball a certain way and it effecting my shot is better than tiger woods.  just my opinion.
big daddy
« Reply #13 on: January 04, 2005, 04:44:53 pm »
Doc-
  • Last login:April 09, 2007, 01:04:51 am
  • Carpe Arcadium!
    • Doc's Modular MAME
« Reply #14 on: January 04, 2005, 05:15:16 pm »
I have Tiger Woods running great on my machine.
One secret is that I am running a 3" Imperial/Betson trackball with the modified optical wheels from groovygamegear.com  -- This seems to significantly increase the sensitivity of the trackball and also substantially reduces the backspin and mishits.
  http://www.groovygamegear.com/cgi/surfshop/shop.cgi
   They are under the "modifications" selection listed as "Trackball booster kit" for about $10
I recommend them.
Doc-
sofakng
« Reply #15 on: January 05, 2005, 10:52:33 pm »
Hmmm, I installed Tiger Woods PGA Tour 2005 and the text is horribly blurry.  The game is set to the lowest resolution (800x600) so I'm not sure what else I can try?  Is there any way to increse the font sizes?
I'm using tv-out (w/s-video) so I realize thats why the quality isnt there, but regular games (MAME, MAMEWAH, etc) look perfectly fine...
GGKoul
« Reply #16 on: January 06, 2005, 12:05:05 am »
hulkster
SoundDoc
  • Last login:January 18, 2012, 07:24:30 pm
  • I'm a Enigma!
    • DaCab!! (a work in progress)
« Reply #18 on: January 07, 2005, 06:47:51 pm »
Here's my 2 cents with golden tee pc and tiger woods 2005...
I'm running both on the cab, and initially can into the golden tee pc can't hit a hooked shot.... Reset back to normal mouse sensitivity and run through the swing calibration a few times, if you crush the ball during the calibration, it tends to make the sensitivity a low lower. nice normal followthroughs during calibration make the "english" a lot more responsive. Also look for the pc version of the swing guide (mousepad) , I think I last found it on the golden tee PC website, the hooks and slices are opposite if I remember correctly from the arcade machine.
I also ran into the "can't hit over 80%" in TW2005. Are you perhaps playing as one of the default players, such as tiger woods? I noticed that tiger never hits over about 80% no matter what you try, but a player you create can hit the 100% and overdrive shots. But also Tiger woods uses trueswing (tm) technology, which, unlike golden tee which is about pulling back and killing the ball for power, TW requires a smooth and rythmic swing for best results and power.
We usually end up playing weekend golf tournys on the cab now, Tiger woods 2005 is the preference by far, as we've made custom characters using the character customizations (isn't is called trueface?) that look like each of us.....
Now if I can only figure out how to stick a beer bottle in hand and a smoke in mouth, the illusion would be complete.....  ;)
(p.s. NEVER I repeat NEVER create a character that looks like your pregnant wife..... 6 months and she still brings it up every weekend)
Sound Doc
DaCab, a work in progress searching for a better name.....
http://Http://DaCab.DatPlace.com
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
« Reply #19 on: February 11, 2005, 11:24:18 pm »
Does anyone know how this plays compared to the Arcade game "PGA Tour"?
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
sofakng
« Reply #20 on: February 19, 2005, 02:17:20 pm »
Does anybody know how to get this game to work with the ATI HDTV adapter?
Basically all I need is for this game to run at 640x432 instead of 640x480.  Anybody know how I can do this?
Thumperman
  • Last login:March 24, 2006, 02:27:47 pm
« Reply #21 on: November 01, 2005, 07:42:56 pm »
Can anyone tell me how they use there control panel to run Tiger Woods? What buttons play what role in playing the game? I am creating a control panel that I would like to make sure is setup for Tiger Woods PC game.
markrvp
  • NFL Expert
« Reply #22 on: November 01, 2005, 08:00:06 pm »
The keyboard keys I use most playing Tiger Woods Golf are:
ESC
Left & Right Arrows (to turn player left & right)
E - Activates the shot target
1 - gets you out of shot target and back to regular view
What you can do is load a custom keyset into your keyboard encoder to make whatever keys you want be the proper game keys.  The game manual has all the keyboad shortcuts.  This way you would have a default MAME keyset and then a custom Tiger Woods keyset.
big daddy
« Reply #23 on: November 02, 2005, 11:51:44 am »
As far as I remember, I don't need ANY special buttons to play TW.   I have a trackball and the 3 mouse buttons are buttons on my CP.  Other than the joystick (which turns your player) that's all I use for the game.  You may have to enter a players name or something if you're creating a golfer, but for general play all the commands you need are accessible by a mouse (so in my case, the trackball/3 buttons combo).
So for example if you want to change your swing type, you don't need a button for that, you point the mouse to the area in the left of the screen, click the left mouse button and it pops up a menu with the different shot types.  I suppose you could have shortcuts to those actions with buttons, but its not required from what I remember.
markrvp
  • NFL Expert
« Reply #24 on: November 02, 2005, 03:18:02 pm »
The shortcut buttons aren't required, but they speed up gameplay.
SQrL
  • Last login:November 24, 2014, 02:00:29 pm
  • The Game is Never Over!
« Reply #25 on: November 03, 2005, 02:29:50 pm »
FYI:  Pressing "E" (shot target) again will also "get you out of shot target" view... its kinda like a toggle on/off button.
brianoneill
  • Last login:January 27, 2017, 04:44:59 pm
« Reply #26 on: November 11, 2005, 08:08:02 am »
I have tw2004 but not installed.
My cab has no trackball though...is the game unplayable ?
Or can I still navigate menus etc... ?
IG-88
  • Last login:May 09, 2023, 08:29:46 am
« Reply #27 on: November 11, 2005, 06:57:24 pm »
I guess that depends on the configuration of your CP.  ;)
-HarumaN
Generic Eric
  • Last login:March 05, 2024, 09:02:23 am
« Reply #28 on: November 11, 2005, 09:40:40 pm »
my apologies for going OT...
How about Outlaw golf?  I finally found it after misplacing the disc for over a year.  Does it work well with  a track ball?  Need to load it again.
brianoneill
« Reply #29 on: November 14, 2005, 06:43:18 am »
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #30 on: November 14, 2005, 08:56:23 am »
You will be able to load it to your hearts content.  You could use a mouse, but what's the point without the trackball.  The only game I found suitable without a trackball is Golden Tee for the Playstation.  It was a lot of fun for a game lacking the trackball.
