Main > Main Forum
Anyone ever see any plans like this commercial driving cabinet?
Knoxximus:
--- Quote from: GGKoul on August 24, 2004, 03:31:34 pm ---WTF?? $6000 for a Road Range Unit...
Couldn't you like get an old, say, Outrun cab, rewire the steering wheel to a spinner input on an I-Pac and do the same thing? Is that even possible?
zaphod:
I'm not advocating its purchase. :) Just showing to give you some design ideas.
Some recent threads:
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=20166
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=23237;start=msg192021#msg192021
http://www.arcadecontrols.org/yabbse/index.php?board=20;action=display;threadid=21349;start=msg190126#msg190126
Tahnok:
Hmm... I was looking at the second picture on the link given in the first post when I relised that it looks just like a normal cab with a seat!
I have seen peoples' cabs that have a steering wheel mounted in that exact place. All you would have to do is create a seat to pull up to the cab and put the pedals further into the machine. Also, you would maybe need to create some way of tilting the monitor to level.
Generic Eric:
tahnok100:
I am with...except on the monitor. Sure its doable, but not authentic to the expierence...these machines were made to accomodate an average amount of the gameplaying audience. To make the monitor adjustable seems overkill. If you can't see the screen, your probably to small. Tell your guests to ball up their jacket and sit on it.
Tahnok:
Oh, sorry, that's not what I meant. I was talking about making an adaptable cab. Almost all standard cabs have there monitors tilted backwards so you can see them easily when the are standing at the cab. But on a driving cab you are sitting and the monitor is level to the ground.
So, to be able to pull up a racing seat like I was saying you would need to tilt the monitor to level (out of standard cab mode and more like real racing cabs).
Then once you got that sorted out all you would have to do is position a wheel onto the front of your cab (like on Pole Position) and recess the pedals further in (most driving cabs have the pedals quite a bit under the monitor. This would be very easy to replicate
Edit: BTW, I'm 6' tall. I tend to run into the problem of the seat not going back far enough. ;)
Navigation
[0] Message Index
[*] Previous page
Go to full version
