Main > Main Forum
Eliminating the Windows DOS screen..
JustMichael:
Hoopstar, go to the Mame Download page and download the windows command line version.
Hoopstar:
:-[ umm, I must apolagise.. I was/am using the command line version of MAME..
So now I guess I am back at square one - is this something that the FE has control over or can this be switched off within MAME itself?
Gameboy.au:
I have MAMEWAH setup on my PC and it doesn't show the dos screen.
I highly recommend that if you wish to use this, download the MAMEWah Setup utility on his web site, because configureing the entire frontend with your joysticks is a nightmare ;D
JustMichael:
Have you tried Emuwizard?
Minwah:
--- Quote from: Hoopstar on June 05, 2004, 08:25:18 pm --- :-[ umm, I must apolagise.. I was/am using the command line version of MAME..
Set the 'Show DOS Box' option in Emulator Settings > Execution Settings. By default it should be on Auto-Show, but it sounds like you have it set on Yes (ie it will always be shown)...
Navigation
[0] Message Index
[*] Previous page
Go to full version
