Main > Main Forum
GT, Trackballs, and Life
Tiger-Heli:
--- Quote from: FoX on May 11, 2004, 10:38:55 am ---Ok...I'll take a look at the optipac and mouseball hacks. Any consensus and the easier/better approach? I would assume the optipac but....
Opti-pac is simpler to hook up, can support up to two trackballs and 4 spinners and automatically disables one spinner/trackball (for five seconds) when the other one is in use.
For a MouseHack - www.oscarcontrols.com's $9 pre-hacked USB mouse is very simple, but you either need two of them (and both would be active always) or one of them and a switch to select between spinner and t-ball (http://www.oscarcontrols.com/DPDTswitch.shtml)
Hacking a mouse on your own is the cheapest option but requires fairly good soldering skills and some level of trial-and-error as well.
FoX:
Thanks again!
Any pluses or minuses going with a usb hookup for the optipac? I would assume more simplicity again but was wondering if anyone has run into any issues with going that route.
Tiger-Heli:
--- Quote from: FoX on May 11, 2004, 11:13:11 am ---Thanks again!
USB has a plus for using two trackballs or spinners with MAME Analog plus.
I don't know of any Opti-pac USB drawbacks other than lack of support in DOS or Win 95 or NT, but that's pretty obvious.
mahuti:
--- Quote from: Tailgunner on May 10, 2004, 05:21:06 pm ---Actually that's backwards, the mounting plate is for use in a wooden control panel. The trackball wil mount directly to a metal panel without the plate.
OOOPS! That's what I meant, My bad. Sorry for the misinformation...
FoX:
--- Quote ---OOOPS! That's what I meant, My bad. Sorry for the misinformation...
Heh.....thats the beauty of redundancy ;)
Thanks for all the info and help guys. I'm definately going to get the GT trackball from happs before that sale runs out at the end of the month. Sounds like its a good ball.
Now I just have to get my copy of GT (oh...and build a cab)
Navigation
[0] Message Index
[*] Previous page
Go to full version
