Main > Main Forum
slikstick tornado analog settings
Stingray:
This probably goes back to what Minwah said about drivers, etc. I'm running a Mac with OS 9 and the built in mouse drivers. I expect performance would be quite different if you're using a different OS with different drivers.
-S
Minwah:
Just make sure you turn off mouse acceleration - this can affect some games quite badly I believe.
Apart from that I do recall I had to up the sensitivity a lot for most games with my old Oscar Model 1...
steve_pss:
by acceleration are you referring to the speed setting in mame (which i cranked down and that helped alot) or acc. under windows itself?
RandyT:
IMHO, A spinner should always be adjusted so that there is a mechanical correlation to the on-screen action.
In other words, in a game like Tempest, one revolution of the spinner should equal one trip around the "tube" (roughly).
In a game like Breakout, you should be able to get from one side of the screen to the other with a little less than half a turn.
And so on.
I think if you stick to this rule, you can't go wrong, but it'll take some experimentation to get there based on the spinner you are using.
RandyT
Minwah:
--- Quote from: steve_pss on March 22, 2004, 02:30:29 pm ---by acceleration are you referring to the speed setting in mame (which i cranked down and that helped alot) or acc. under windows itself?
Windows itself.
Navigation
[0] Message Index
[*] Previous page
Go to full version
