Author Topic: ISO RGB pushbutton  (Read 577 times)
barryabrams
  • Last login:November 11, 2025, 12:50:36 pm
ISO RGB pushbutton
« on: November 11, 2025, 12:37:02 pm »
I’m looking for a translucent pushbutton that has an embedded neopixel/ws2812. I found t sticks 2-in-1 button which would work great if I needed a 2-in-1 button, but I really need a non-split regular button. Anyone have a source?
criteriascenario
  • Last login:December 05, 2025, 07:10:13 am
Re: ISO RGB pushbutton
« Reply #1 on: November 23, 2025, 10:56:32 am »
Hi, I’ve worked on this issue before and it usually comes down to a configuration parameter that the machine won’t run without when the chuck status isn’t detected correctly. There are a couple of work-arounds depending on the exact SE2200LM control setup you have.
If you want, I can guide you through the steps I used to bypass the chuck-close requirement and get the machine running with a manual chuck. Just send me a message and I’ll walk you through it.
You can reach me at: creedtech7 at gmail dot com
Sent from my A11 Pro Max using Tapatalk
