Main > Main Forum
6-Pin Female Molex
<< < (2/2)
LoRDDeVO:
Molex pins for a betson trackball will fit into a molex connector for a computers PSU if that helps. the way I have my trackball connected without coutting the molex adaptor off is i removed the pins using a pin remover from radioshack. http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=274-223.
then i just used an old 4 socket molex connectors from a old broken comp fan connected to a mouse hack and presto it works.  the good thing about it is that you can use the 2 power pins from the trackball and stick them directly into a molex connector on your PSU for your +5 V
SirPeale:
I know those are the same size, but I don't know what size those are.
mp2526:
they are .093
I bought the .062 and they are too small.
here is a link to mouser's pdf page.
http://www.mouser.com/catalog/617/745.pdf
I'm fairly certain that model number 538-03-09-1061 is what you need.  It is panel mount, but should still work like a free hanging as well.  They don't carry a free hanging one in size .093 for 6 socket.
I bought 538-03-06-1062, it was the exact type I needed, but it was size .062 and was too small.
SirPeale:
Fantastic.
What's panel mount?
mp2526:
I believe that just means that it has clips on the side that allow it to attach to a piece of sheet metal, so it can be mounted in a metal enclosure.
Navigation
[0] Message Index
[*] Previous page
Go to full version
