Author Topic: Suggestion for supergun builders..  (Read 1444 times)
JoeB
  • Last login:April 03, 2024, 11:38:08 pm
  • NES Fanatic
« on: March 04, 2004, 10:53:05 am »
Here's a suggestion for supergun builders ...
why not build a supergun into a 3 1/2 or 5 1/4 enclosure?? You know, those 40$ things you can buy anywhere that converts your hard drive or CD/DVD drive into an external USB2 or Firewire connectable device!
The great thing about these enclosures is:
- they look cool - otherwise no one will want to buy it
- it has a build in full functioning power supply (outputting all the required power!)
- it has a build in fan - to keep all the circuits nice and cool
- it's cheap!
Let me know what you think...
CitznFish
  • Last login:May 26, 2023, 12:36:44 pm
  • www.subvertcity.com - Prof. Strength Slackwear
Re:Suggestion for supergun builders..
« Reply #1 on: March 04, 2004, 01:26:55 pm »
when will Supergun builders start mass producing these so you can play Jamma games on your TV? :)
gnateye
  • Last login:December 05, 2011, 11:22:36 am
  • 4 cabs and counting!!!
    • natty's arcade
« Reply #2 on: March 04, 2004, 10:33:38 pm »
it doesnt seem like its that hard to build one, especially if you already can build arcade controls, its just an arcade power supply (30-50$) a nice jamma harness or 2 (20-30$) one of those rgb converters (80$) or supposedly you can hack a dreamcast vga box (10-20$)for the rgb conversion (if anyone knows any more about this please pipe in) then connect it to your joystick/control panel or use hand held controllers or whatever, and voila, use the enclosure mentioned above or whatever you desire.
CthulhuLuke
  • Last login:January 18, 2024, 06:42:43 pm
  • old school
    • CthulhuLuke's Arcade Parodius
« Reply #3 on: March 05, 2004, 03:39:03 am »
http://www.massystems.com/SuperNova.html
they actually aren't that hard to build, I was pumped to build one until I looked at the cost of a jamma to NTSC convertor $95
http://www.arcadeshop.com/rgb/rgb.htm
and  http://cps2shock.retrogames.com/jamma.html  has an entire thing on creating your own supergun.  I'd still like to make one in the future when I get some arcade boards, but its kinda something if you already have some jamma boards and other boards it'd be very cool to have.
