Main > Software Forum
Wheel2XInput, designed for mapping wheel and wheel accessories to XInput
<< < (10/10)
Eckers569:
There’s a lot of cross-over between this and x360ce to be fair. However, for me at least, I got fed up of x360 constantly deleting settings and never really getting to grips with the per game configs. Never had any such problems with W2X.
Another key benefit is not only being able to map multiple devices to single xinput bindings (which you can also do with x360) but then with any of those individual devices also being able to map multiple buttons from them to a single xinput outputs- which you can’t do in x360 (it will clear a binding if you try to map elsewhere on the same device - see my crazy taxi example above). There’s also I believe benefits of being able send FFB to multiple devices which I’ve yet to explore.
nugarp:
--- Quote from: ark216 on December 09, 2025, 06:58:37 am ---How does this software differ from x360ce. I would really like to test this out with my G29 but since it does not have GUI and is just code based it looks a bit intimidating. Are there any easy user friendly guides where i can follow? I did check it's README, i found it to be a bit confusing.
Just wait a little bit. I have been pushing hard on an update that was worth the wait. I've been fortunate to have a team of beta testers in the discord that have been helping iron it out. I will update this thread when it is ready. Guess the software didn't die in 2022 after all!
--- Quote from: Eckers569 on February 16, 2026, 12:40:36 pm ---There’s a lot of cross-over between this and x360ce to be fair. However, for me at least, I got fed up of x360 constantly deleting settings and never really getting to grips with the per game configs. Never had any such problems with W2X.
Thanks for responding. You are correct, you can do one-to-many and many-to-one mappings. There will be a lot of fine-grained control that I think will be more relevant for anyone with an FFB device than a generic x360ce implementation.
eljulo:
Hi ! Thanks for your hard work on this one !
I actually work on your wheel2xinput for Outrun2006Tweaks by Emoose to try to improve the ffb effects.. I explain : this works amazingly well. But in Outrun FXT by Howard Casto, i figured how to optimize the spring effects on the game i i'll love refind this feeling with your stuff.
This is what i do : I try to set up the spring effect you add while the car drifting : in fact, when the car begins to drift we have the vibrations but the spring effect disappears and i will love have the spring effect while drifting (like in the arcade). Well, i spend maybe 5 days to try differents settings with the IL  but with no success  :banghead:. Do you think you can take a look on your program pls ?
Best Regards
Julo.
robertdeniro22:
Hello everyone, I hope this is still active. Does anyone know how to configure the D-pad on DualSense? All the buttons work perfectly except the D-pad directions.
nugarp:
--- Quote from: eljulo on April 20, 2026, 08:15:45 pm ---Hi ! Thanks for your hard work on this one !
Best Regards
Julo.
This is fixed and adjustable in 1.6, which is in beta.
--- Quote from: robertdeniro22 on April 25, 2026, 10:46:41 pm ---Hello everyone, I hope this is still active. Does anyone know how to configure the D-pad on DualSense? All the buttons work perfectly except the D-pad directions.
You should use the --trace command and it will tell you what the input mapping for the dpad is. What does --trace look like when you push the dpad buttons? Usually, dpad is listed as dpad instead of axis or button.
Navigation
[0] Message Index
[*] Previous page
Go to full version
