Author Topic: Donkey Kong PCB Repair: Coil/Inductor identification  (Read 1197 times)
ArcadeFormer
  • Last login:September 01, 2022, 02:05:58 pm
« on: August 07, 2022, 09:57:54 pm »
Does anyone know where to get this coil?
He has 4 pins and looks like an isolator with 10nH:20uH or something like that.
I've attached also a schematic (Coil: T1)
« Last Edit: August 07, 2022, 10:02:03 pm by ArcadeFormer »
lilshawn
  • Online Online
  • Last login:Today at 01:53:02 pm
Re: Donkey Kong PCB Repair: Coil/Inductor identification
« Reply #1 on: August 09, 2022, 01:24:05 pm »
there isn't much to it... just an isolation transformer for a clock signal (probably to keep noise out of a subsystem.)
not much can go wrong...so I'm wondering, why you need to replace it?
quite honestly, you could rewind it with appropriately sized enamel coated wire...if the toroid is broken... find one of a similar size and rewind it. count the turns and wind 'er up.
