Author Topic: Not able to connect MK1 Kick Harness into JAMMA TO CHAMMA ADAPTER  (Read 1462 times)
loskiorama
  • Last login:February 20, 2022, 10:31:24 am
Hey Guys, I have an original Mortal Kombat 1 cabinet, and I'm having trouble connecting this Jamma to Chamma adapter to my kick harness:
https://www.mikesarcade.com/cgi-bin/store.pl?sku=JA-CHAMMA
The problem is that my kick harness connector has a blocked "socket" as you can see in the picture below:
I can remove the connector and solder the wires directly to the JAMMA TO CHAMMA board, but I'm not sure which pin corresponds to which cabe
All I know is what each cable represents on my kick harness as this MK1 arcade manual shows
, but I need to know this for the adapter as well to make it work.
Any help would be appreciated
