Main > Driving & Racing Cabinets
Daytona USA 2 and Le Mans 24 now work full speed in Supermodel Network!
<< < (5/6) > >>
vandale:
--- Quote from: MrThunderwing on November 03, 2021, 04:46:55 pm ---Sega Rally 2 works now too! That's all the Model 3 racer games now working in link-up and full speed 🥳
Awesome, been hanging out for this one :)
buttersoft:
Woot. Thanks once more for the heads up, MrThunderwing!
dgrace:
Hello, I could use some help linking up two separate PCs trying to play dayto2ape.
MASTER PC config ini:
; Network board
Network = true
SimulateNet = true
PortIn = 1970
PortOut = 1971
AddressOut = "192.168.86.48" (my slave IP address)
SLAVE PC:
; Network board
Network = true
SimulateNet = true
PortIn = 1971
PortOut = 1970
AddressOut = "192.168.86.47" (my master PC IP address)
Master PC dayto2pe rom test menu set to Master 1 and Slave PC dayto2pe test menu set to Slave 2. When I try to link them on the same PC it works great, no problem; its just when I try and link on separate PCs. I'm using the latest supermodel download. Firewall settings look good as well. Trying to link over wifi, just FYI. Any suggestions greatly appreciated. Thank you
Nuexzz:
change "true" to "1" example
--- Code: ---Network = 1
SimulateNet = 1
--- End code ---
dgrace:
--- Quote from: Nuexzz on October 24, 2022, 05:20:50 am ---change "true" to "1" example
SimulateNet = 1
--- End code ---
Didn't work unfortunately. Not sure what else to try. Anyone able to get it working on 2 separate PCs or just on one PC? Also, has anyone got it to work via wifi, or only LAN? Thanks
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
