Main > Raspberry Pi & Dev Board
Like a SmartStrip but controlled by a USB type B plug?
pbj:
Good. Otherwise I’d have made you retire that forum handle.
keilmillerjr:
I have the EcoStrip 2.0 1503E. It has a master power outlet, and switches the 5 other power outlets based on 5v from usb. It works great. It is now discontinued and website isn't even up anymore. Bummer.
MacGyver:
--- Quote from: keilmillerjr on June 20, 2020, 06:35:06 am ---I have the EcoStrip 2.0 1503E. It has a master power outlet, and switches the 5 other power outlets based on 5v from usb. It works great. It is now discontinued and website isn't even up anymore. Bummer.
That was exactly what I was looking for. Thanks.
keilmillerjr:
DGC smart strip is still in production. Controlled by amps pulled from master.
https://www.dgcproducts.com/bitsltd.net/
MacGyver:
--- Quote from: keilmillerjr on June 21, 2020, 06:08:02 am ---DGC smart strip is still in production. Controlled by amps pulled from master.
Maybe it's the age of mine or the fact the computer is trying to be green but I couldn't keep mine from bouncing every now and then. That's why I modified it the way I did.
Even still, nothing beats the one you referenced, that is what I was trying to find but couldn't because of all the USB charging ones popping up in my searches.
Navigation
[0] Message Index
[*] Previous page
Go to full version
